Sony GT420IP No Power Problem
mike689
I've got my brand new sony GT420IP head unit all wired up but for some reason it wont turn on. I've checked to see if there is power coming from the red wire out of the car and it is giving off like ~13.5 VDC, so power is going to the unit it just wont turn on for some reason. I have tried switching the yellow and red cords around. I also tried connecting the red and yellow wires from the head unit both to the red wire and it worked for a few minutes then turned off and will not work again. If anyone knows how to fix this problem your advice is very appreciated.
Yeah the fused popped, but that wasnt my initial problem however i fixed it by twisting the red and yellow wires together on both the head unit and the wiring harness and then twisting red+yellow to red+yellow so now it gets power and has memory. thanks for your help anyway
back to the ghetto you go!
i would check and replace any bad fuses, wire it correctly. and re-install it.. the right way...
ur welcome //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And then you'll accidentally leave the radio on one night and you're battery will die.
Wire it correctly.
mike689
mike689
Birmingham, AL
mike689
michigan born
    May 14, 2026
michigan born
    May 14, 2026
