R riddla 10+ year member CarAudio.com Elite 675 0 nf Dec 29, 2007 #1 How do I wire this to 1 ohm to run of my hifonics 1600w mono 1 channel amp please as i haven't got a clue. Click to read more...
OP R riddla 10+ year member CarAudio.com Elite 675 0 nf Dec 29, 2007 Thread Starter #4 does this mean that this sub is useless to use on this amp then
tapout 5,000+ posts CarAudio.com Veteran 12,757 17 Ga Dec 29, 2007 #5 you don't /thread Click to expand... indeed
T tRidiot 10+ year member Perpetually dissatisfied 2,494 0 OK Dec 29, 2007 #6 No, it means you wire it to 2 ohms and your amp will give the amount of power it's rated for at 2 ohms.
bonesninja 5,000+ posts CarAudio.com Veteran 15,380 11 Lima, Ohio Dec 29, 2007 #7 no it means you can't run it at 1 ohm.....you can run it at 2 ohms tho, which will give you about half the power that 1 ohm does
OP R riddla 10+ year member CarAudio.com Elite 675 0 nf Dec 29, 2007 Thread Starter #8 ok, can I use this sub or cant I please, dont really understand my options
tapout 5,000+ posts CarAudio.com Veteran 12,757 17 Ga Dec 29, 2007 #9 does this mean that this sub is useless to use on this amp then Click to expand... not useless, you can wire it too 2, you just wont be giving it alot of power. What is the sub rated at? The amp at 2?
OP R riddla 10+ year member CarAudio.com Elite 675 0 nf Dec 29, 2007 Thread Starter #10 the sub is rated at 600rms and the amp at 1600w rms at 1ohm
bonesninja 5,000+ posts CarAudio.com Veteran 15,380 11 Lima, Ohio Dec 29, 2007 #11 the sub is rated at 600rms and the amp at 1600w rms at 1ohm Click to expand... well then wire it to the amp at 2 ohms and that'll be what you need
bonesninja 5,000+ posts CarAudio.com Veteran 15,380 11 Lima, Ohio Dec 29, 2007 #13 oh shit...you gotta be kidding me
T tRidiot 10+ year member Perpetually dissatisfied 2,494 0 OK Dec 29, 2007 #14 That sub needs 600RMS... and your amp at 2 ohms will give it around 1000 watts... I think that's plenty. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
60ndown 10+ year member CarAudio.com Veteran 3,661 1 ca Dec 29, 2007 #15 the sub is rated at 600rms and the amp at 1600w rms at 1ohm Click to expand... then your amp wil do about 600 at 2 ohms which means its a perfect match. nice sub, what amp you gots?
