engine noise
well, do you have ext crossovers? like for components? seems that when I put my crossovers under my dash that they picked up engine noise somehow...idk, what all have you tried?
yah i do have a crossover under my seat for highs and lows. but when i connect everything straight i dount get any noise. ive also tried getting good rca jacks noise filter, rewired everything triying to make sure that there wasnt any ground close to a power wire.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Your entire chassis is ground.
What headunit do you have
I have a sony XPLODE. what I did try was changing the location of the crossover from under my seat to behind the seat. The noise aint that bad anymore but theirs still some noise.
thats the problem.
hmm. try mounting them higher.
like not on the floor like on the wall of your trunk. cause sometimes the lower the wires are the more interference you will receive.
just a thought.
not a proven concept.
thats the problem.
just a thought.
I have wires in every configuration you can think of and zero noise.
Most likely your problem is a loose connection or a ground issue.
romans535
romans535
E.L.A, CA
ultimate157
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
