dual 4ohm voicecoil wired to 1ohm help
ok, so I basically I wont be using my amps full potential then correct. whats the best way around this. should i change the amp if want at alot more power or change the sub for a 1ohm sub if thats possible
I have the hifonics brutus 1606D
just get 2 D4 R's or 2 D4 L7's and be done with it.
that amp and sub combo will be very nice when....if , you get it wired correctly,
loud and clean, no need to change anything.
should rattle everything petty good
you just dont need 1600rms and 150 db unless you want to win a stupid tall trophy
looking at your pic, it looks like you got it wired to 8 ohms, whic means it will be about 4 times as loud when you wire it to 2 ohms //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I do understand it but thought 1600w rms would be more beefy than half for the sub, correct me if im wrong
Yes, I had the + to a - on the sub and then + to the amp & - to the amp, was that 8ohms
riddla
riddla
nf
bonesninja
