dual 1ohm subs wire to .5 ohm or 2ohm
I would go with sundown dc american bass
---------- Post added at 03:46 PM ---------- Previous post was at 03:45 PM ----------
Im choosin a sundown 5k for my 2 tantric hdds n i was thinkn bout strapping 2 brutus amp l. Glad im goin with one nice burly amp
so whats better? 1 amp running at .5 ohm, or 2 amps each running at 2 ohm, that was the original posters question. Which way is more efficient?
If there running the same power u probably wont notice a difference
---------- Post added at 06:09 PM ---------- Previous post was at 06:08 PM
But buyimg 2 amps to get the same power u can get outa 1 amp at .5 is crazy
I have never looked this far into it but is an amp more or less efficient at .5 ohm? Compared to 2 ohm.
Is an amp going to have more or less distortion at .5 ohm? Compared to 2 ohm.
Has amp one every actually tested this?
Yes again and again .the lower u drop impedence the more distortion amd less efficient a amp becomes ..now there are amps that are better and worse at handling these drops but u probably wont notice a diff .if u have the proper electrical to support the amount of power u plan on running
So... it would be more efficient using two of the same size amps vs. a larger single amp at less impedance...if that's what I am understanding that's what I was looking for...
Another question would be would the two amps pull the same or more/less current than the larger lower efficient amp? Just trying to get a general understanding. Thanks
So... it would be more efficient using two of the same size amps vs. a larger single amp at less impedance...if that's what I am understanding that's what I was looking for...Another question would be would the two amps pull the same or more/less current than the larger lower efficient amp? Just trying to get a general understanding. Thanks
No what im saying is if they do the same power u will not notice a difference if ur car is electrically setup to handle it ...1 amp is just simpler and gona be alot cheaper to buy .5ohm power vs 2 ohm power ..its pretty simple
592
726
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
942
BoomTaco64
BoomTaco64
gone...
NASTY08IMPALA
