dropping avenger
$300 is rather pricey, considering it is a job that could be done in your driveway in a matter of a few hours with rented tools from Autozone.
My sugguestion. Get some friends with mechanical know-how. Buy a 24pack. Invite them over. Get to work and enjoy some cold ones afterwards.
And ANYTIME you have suspension/wheelandtire changes, you should go get an alignment afterwards.
FYI, My full bodied coilover install ran $100 in Florida (known for high priced labor), and it was much more intricate as we had to dial in all of the height/rebound/camber/toe settings. I would sugguest checking with smaller tire/suspension shops as they will usually charge less due to less overhead.
The good part is, it's rather hard to mess up a spring install, so you need not worry about quality labor. Have your lugnuts tightened afterwards though, to avoid any problems with loose wheels.
Welcome to the forum. I look forward to seeing your progress.
For awhile I was running 80ah yinlong on a stock 100-120a alt. Smart 5 sub amp and Audison APF8.9 bit stage amp. My voltage never dropped more...
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
armitank
Banned
armitank
Vancouver, Canada
Loud3
    May 16, 2024
    May 16, 2024
