drop it...
they are 9 rear, 8 front...
10's wont fit on the rears...
I need to lip the rear guards, and get some offset bushes, to correct the camber, which will bring the wheels further out...
the rims are +35 offset all around, which is why the fronts are sunken in... I bought them second hand, so it doesn't really bother me...
lower.... lol //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
10s will fit in the rears, hell 11s will, your just too *****-shit to do some fender work... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
nah duh, 15 inch wide rims would fit at the back, but you're an idiot //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Meh I'm done with you, just trying to help you out with your shitty wheel fitment, just don't expect to get any compliments from real enthusiasts...
your "help" is telling me to get wide guards, and wider wheels!?!?
you're clearly a f*ckhead //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just for kicks, this is an example of what your car SHOULD look like...
Wheel specs: 235/35 on 19x9.5 (w/ spacer) +24 & 245/35 on 19x10.5 +19
Little fender work can squeeze 265s or even 275s in the rear //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and ah... how has the camber been corrected on that? or hasn't it been?
I'm sure its a modest amount...Camber wear isn't really as bad as people say it us SO LONG as your other alignment specs (specifically toe) are in order //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
that car, would have neg 3 degrees of camber, with the adjustment maxed out, and no traction whatsoever.
camber wear isn't the problem here... traction is...
It was only an example, a less aggressive offset could be used, be flush with the fender (in turn widening your track, hint hint), and still be at an acceptable camber (-1 to -2 is nothing). One point of running wheels that are flush is to use your car to its full potential, not just for looks. Think about it, why do you think a lot of professionally driven performance cars have fender flares? Example:
the camber isn't because of the width, or offsets, its because the car is dumped on its *** :s
There are a lot of adjustable after market parts that can correct camber problems easily, theres a lot more to suspension then just struts/springs and coilovers. You have a lot to learn my friend //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have learnt...
there are no offset bushes, no adjustable camber arms, no adjustable wishbones, etc available for the Aristo / GS300...
feel free to prove me wrong.
http://www.nagisa-auto.com/products/spa_toyota/index.html
Parts are kind of mixed up so search for your car...Code is JZS14 (or 14 Aristo) if you didn't know...
Thats ONE example, took me two seconds, have to know how to search...
and.. pretty much, the only bit in english on that website is "Seller will not ship internationally."
Death By Bass
WHATS A SUBWOOFER!?!?!?
Death By Bass
Adelaide, Australia
Death By Bass
