Drilling through the foam surrounds to mount sub.
ChiefontheDitty
So I just got my XXX 15 back from a recone and I noticed that the holes where you would screw the sub down are covered with the foam surround. I was thinking that since the sub is so heavy it wouldnt really matter or should I just screw it? The box is the "crx" style box. Where the cone is facing up instead of towards the tailights. My other question is, on the sub there are 4 pos. neg. (red,black) wire connector things. When the guy install the sub and amp is he suppossed to hook wires up to each one of them or just one? It will be off of a Viper 1200. Any help would be great. Thanks, Chief
Somebody please help me. Also when I take it to get installed I was going to write down my current mileage and I was going to sign it and get the guy to sign it. You think that would come off rude?
definitely screw it down. don't worry about the foam covering the mounting holes, it's suppose to be like that when you get a new sub/recone.
drill through the surround to mount it, dont just stick it in there lol. he needs to wire it in parallel (pos to pos on sub to pos on amp and neg to neg on sub to neg on amp)
So if I am not mistaken that would only cover two of the four wire connector things on the subs. So should the installer guy go pos to pos to pos to pos on to to pos on amp and the same for the neg. Or is that just completely wrong.
How do I tell? By what I understand it is 1ohm stable. I thought bridging was a bad idea. Does somebody know if the Viper 1200's are 1ohm bridged stable?
If you jus look on Viper's site. you could see that the amp can do 450 at 4 ohm, 800 at 2 ohm, and 1200 at 1 ohm //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You weren't seriously asking if you could just sit the sub in the hole were you? lol
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif hehe i think so //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
ChiefontheDitty
ChiefontheDitty
Sweetwater, TN
NofriendsSpongr
michigan born
    May 14, 2026
michigan born
    May 14, 2026
