Down to 4 sub choices, need help to finalize,take a min to look please :)
T/S D4 / D2 **:
RE: 7.09 / 4.33 Ohms
Fs: 28.4 Hz / 30.3 Hz
Qes: 0.511 / 0.519
Qms: 5.75 / 7.25
Qts: 0.469 / 0.484
Vas: 40.3 L / 29.07 L
BL: 25.04 NA / 22.16 NA Le: 7.7 mH / 4.73 mH
Mms: 252 g / 308 g
BL^2 / RE: 88 / 113
600 watts RMS
thats the sa12 dvc4
the biggest differences between the 2 ( other than the zues has 2 sets of spaced spiders )
is the bl is a tiny bit more on the sa but the z12 has alot less mms and a lower fs
very close other than that...even box specs for both are almost the same...
so again cone area wins... just my opinion tho
was impressed with the 8's and 10's tho but not for the 200 a pop price tag at all ...
if the sa8 comes in a dvc2 then yes...
like this:
youd get around 300 - 320 rms per sub
i was impressed at how low the pair i heard went.. they were hitting 25 and doing it pretty loud on 1kw to the pair..very clean as well
but so do the Zeus.. that was my only point...
all the subs he listed are gonna rock his world in that tiny cabin... he has a Z or am i the only 1 paying attention? it is a hatch car... a fart will flex the glass lolz
but given the fact that he can do 2 zeus for less than 1 of anything else and still bang hard loud low and clean and use the extra $$ saved on a custom box.... no brainer imo...
in all reality he should do 1 12" RD sonance dvc2 in 1.25 sealed or 1.75 ported at 32Hz and **** even the sa12...
but the Sonance is not in his range...
If it's the right sub tho Il pay the extra cost. Do you have a link to this sub?
I like that setup for the SA-8s Il see if they are dvc2, whatever that means.
they are a bit spendy and no you would need a custom box most likely... they are massive subs...more geared to SQ but put out some serious SPL
in all honesty any of the original subs you listed are gonna be more than you are expecting. you have a hatch.. subs up port back and your gold with even low end subs on 750 watts...
The Sonance is the best sub listed in this thread. Those things have a fine blend of spl and sq...
And sicaudio is right that pretty much anything in your car on legit power will sound loud to you...
And sicaudio, BL does not categorically implicate how loud a sub will be. It also has to do with the mass moved, weight/strength of spiders etc
I know dude... been in this game for 25+ years
the mms of the zeus is way less and it has double the spider ( 2 seperate 4 layer polycotton spiders spaced almost an inch apart vs the sa having 1- 4 layer..) that makes it get louder on less power... high bl and low mms = efficiency...less power and more boom //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
both are great subs imo i was basing my suggestion on $$ so he can get a real box instead of a prefab with the savings...lol
as for the sonance i cannot say enough good about them
RD has been my boner for along time lol
not many people do a 152 in a hatch in an sq install lol they really surprised me with the new models tho.. took 1200 rms each and wanted more..
boomboom23
boomboom23
Wi
boomboom23
