door handel(s)
  • 2
SAVAGE SOUND
CHICAGO
OK ive got my doors SD pretty well (no rattels except) the prob is the door handels rattel when i crank the system. i cant relly put any more material on the inside because it will get in the way of the handel components. i was thinking of using a drop of super glue on each coner while pressing on it, but i think as the car weathers it may cause discoloration or just look odd. is there any other options beside superglue or shaving and selinoids?
I imagine that you are talking about the outside handle.? What are you talking about supergluing? What are the handles made of, metal or plastic? Are you sure that it is the handle it self or could it be the connecting rods?
You could remove the handle and plastic piece and put a thin peice of black foam gasket under it. I imagine that it is ratteling against the metal of the door....so in that case...you could possibly get some foam or rubber gasket material at an automotive shop.
FYI......
Aftrer you take the door panel off, remove the rod going to the handle. Then remove the nuts (more than likely a #10) holding the handle and it should come right off.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
183
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
512
Tons of options in that budget, including the cost of installation,
10
813
SAVAGE SOUND
SAVAGE SOUND
CHICAGO
Trixter
    May 16, 2024
    May 16, 2024
