doing an install with an output converter ?
jart27
Hey gang, doing an install and got an rca problem. When i plug either L or R into the amp it plays ok, but when i plug both rca's in amp wont play. never had this prob and dont understand why it would play if i had a wire wrong from installin the converter. Any troubleshooting ideas?
Thanks, Justin
Is it that i may have switched a positive or a negative in one of the channels which would make the signal not run parallel
If you are using an LOC to convert L/R speaker outs to RCA for a sub amp that is bridged, then if you have *one* of the speaker connections swapped it will only work when one RCA is plugged in but not both - this is because the L/R channels are out of phase and cancel each other out. Double check your L/R speaker wire connections to the LOC.
jart27
jart27
cape coral,fl
jart27
