Doesn't crackling sound mean speaker is bad?
  • 4
dannieboiz
Bay Area
The mid driver on the driver side of my MB Quart Q series has a crackling sound on certain notes. Most of the time I'll hear it but on some songs I can't even tell. Does it mean I have to replace it? I've popped the door panel and see the driver is playing just fine. When I press the driver in with my fingers I can still hear sound and the crackling goes away.
measure the voice coil resistance to find out if there is any damage.
to me it sounds like you are hearing tweeter distortion. turn your gain down and see if it goes away
^^ this, or try swap your rca's (left and right) on your amp (if you have one), if the sound starts to come from the other speaker then the problem is in the signal and not the speakers.
look closely at the surround and where it connects to the cone and basket. The surround can separate and then the speaker makes noise due to being unbalanced. Can be fixed with a medicine syringe and silicone making a small bead on that seam (entire circumference)
Or loose mounting screws.
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
986
Mixed Mono has also been around for many years from the 80s as well. Ill use a set of 4 ohm components with a passive Xover and throw in a 4 ohm...
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
dannieboiz
dannieboiz
Bay Area
keep_hope_alive
maylar
    Jun 2, 2024
    Jun 1, 2024
