Do I need to re set the gain
I just changed my Incloser to a slot ported box from sealed do I need to re set the gain on my amp
if you did it with a DMM i wouldnt think so. because you set it the estimated "max rms" output. but if you set it by ear, iwould go buy a cheap multi meter and set it that way
If it was set correctly to begin with, it will not change. The gain is set based on the output of your receiver, it has nothing to do with the box, unless you are overpowering your subs and need to dial it back a bit.
Quinn88
Quinn88
Eugene, Oregon
Quinn88
Mike Mccabe
