Do I need them?
  • 4
rsrguy
CarAudio.com Recruit
I have an old 911. I'm using component speakers up front an under seat powered sub, and 2 pioneer 3" in the dash where the single speaker once resided. I'll be running the Kenwood BT amp and an audio control eq /dac (under the other seat).
I don't know if i want rear deck speakers, I've heard rear speakers were for passengers, but my passengers are little kids (which is why I'm not putting subs in the package shelf).
If I do want speakers, I'm kinda lost, do I need to keep with the component type, or should I use 6x9's? Do 6x9's utilize x-overs to improve separation, when I was younger they were just a standard deal we just threw them in and drove. Now I care about audio quality.
I'm planning on an aux cable for music input, and Bluetooth for phone and JRE.
Advice?
No sure what sound improvement you would get by adding rear deck speakers. Not a lot of room in the car you have pictured. Are you happy with the current sound? If so, forget the rear speakers.
Yes there is enough room, and if I get the clover style enclosure they'll have a place to mount.
When I said there wasn't a lot of room, I was referring to your sound stage. Would adding more speakers improve your sound, or create a situation that is not pleasing to the ears. Only you can decide this.
The clover style housing looks like a good option, esthetically, if you really want rear speakers.
Good luck.
Got it. Thanks I'll leave it alone for now, on to figuring out which compact sub, any suggestions? Don't care about rap, I'm looking for accurate clean reproduction.
My experience with subs is limited to Polk Audio and Kenwood. I had 2 - 8" Polks and now I have 2 - 12" Kenwoods. Both were installed in Mustangs. The current Kenwoods are satisfactory, but I liked the Polk better. Better audio quality, in my opinion.
I'm sure others can offer more suggestions on subs. There are many quality brands out there.
Advice?
I say get good quality speakers with horn tweeters for the front and a good quality amp for them. Kicker has mini amps that fit in the palm of your hand for easy location.
rears just usually screw up the sound quality. you can run just some midbass speakers in the back and play from 200hz down, but i wouldnt bother. i never run rears... only comps upfront, sub in the back
ps, nice ride
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
346
358
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
rsrguy
rsrguy
Northern UT
rsrguy
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
