Do I need new alt/battery/cap?
A good battery such as an XS Power, 1/0 cables, good grounds to start. 1/0 ground from battery to body, battery to engine and replacing the alt lead from alt+ to batt+ to insure proper flow.
A second battery may be desirable dependent on the draw the amp places on your system. If you still need more you can get a high output alternator.
Start with the basics. Good battery, good cables, good grounds. Go from there as the need arises.
If you need good batteries or a high output alternator contact mlogan@mechman.com.
First step is Big 3 upgrade.
Second step is AGM front battery.
Third step is HO alternator upgrade and/or second AGM rear battery.
Do one step at a time until you have stable voltage (voltage>12.6v) at the amps.
best_predator
best_predator
Orlando, FL
audiolife
