Sergio6265
Im getting a 4000 watt amp (vibe286) and i dont know if i need a second alternator or a bigger one.
if u play when the car's off.If i dont buy the extra alt or batt will my stock battery die.
So if i dont play when the cars off my battery wont die and is a 4 farad cap enough.if u play when the car's off.
Do i really need one because the owner manual says itsyou definately need a ho alternator. do the math. at full power your amp will draw 400 amps or so. but on average probably about 100 amps depending on the kind of music you listen to. your alternator will need to supply at least 100+ amps just for the audio system in addition to enough amps to run the cars electrical loads. a battery will help if you run your audio with the engine off, the alternator supplies power when the engine is running, otherwise it will be an additional load on your alternator. the cap(s) may help provided your alternator can provide enough current in the first place, as they will level the load on the alternator. and provided they have a low esr (equivalent series resistance), and esl (equivalent series inductance) otherwise they're worthless.
It says on the box and on the websitewell that's a different story. where did you get the 4000 watt figure from. so at full power it will pull 70 amps. with an average current draw of say 14 amps figuring music with a 20% duty cycle. you will probably be fine with your stock alternator.
