Do I need an additional battery?
morbidj
My setup is as follows
Big 3
0 Guage from battery back
4 guage to each amp
Amps:
door speakers
1x Kenwood KAC-8452
800 Watts max power
70 Watts x 4 max (4 ohms) RMS
90 Watts x 2 (2 ohms) RMS
Sub amps
2X Kenwood X811D
Maximum Output Power (14.4V): 1600W
Rated Output Power (14.4V)
400W x 1 at 20-200Hz 0.5%THD (4 Ohms)
800W x 1 at 100Hz 0.5%THD (2 Ohms)
Over 1000W x 1 at 100Hz 1.0%THD (1 Ohms)
Rated Output Power (12.0V)
300W x 1 at 20-200Hz 0.5%THD (4 Ohms)
600W x 1 at 100Hz 0.5%THD (2 Ohms)
I have 2 06 L7's with dual 4 ohm VC's to present a 2ohm load to each X811D amp.
They are in a 5cube 35hz tuned box; dont know if that matters...
My alternator is 130amp in a 03 grand cherokee
Im having the wiring finished tomorrow and am thinking about picking up a 34 yellow top from autozone and having that installed. Is the extra battery in my case a necessity at this point, good idea, or just a waste of money? Caps are expensive I would rather run the battery over a cap..
i would get the better battery and think about a ho alt. and don't even worry about getting a cap, it wouldn't help you out. at peak your system will draw at most 1600a+ depending at what load your speaker amp is wired at. i would think about a 200a alt. if i was you. without one you probably wont see the 800w to each sub.
morbidj
morbidj
Denver
matrxx dude
