amp (clicking) problem
rhruska
just hooked up my amp and it worked at first but had a voltage problem which caused it to click off at loud volumes. the problem is now to the point that the amp clicks about every second at low volumes so i just unhooked the amp until i can find a solution. also the amp shuts off in the middle of the clicking sometimes...i have checked all my wiring so i'm not sure what to do besides trying to get an amp replacement. thanks for any help
no, protect is not on. it was for a little bit right when i installed it but then went away and it worked fine. when wiring the subs to put the dvc's in series you wire the positive and negative from the same coil to each other right? not a positive and negative from different coils? i'm totally at a loss. will onlinecarstereo replace this amp for me?
ok, so there is a noticeable smell coming from the amp so i guess it's fried. what are the chances that it's a defect in the amp? i really don't want to get another one and have the same thing happen. this sucks
rhruska
rhruska
Fort Worth, TX
rhruska
vegang
vegang
