do i need a Subsonic filter
box is tuned to 35hrz and i live on 43rd and bethany home ruffly
do you really need a subsonic filter i know it filters out feq's that the human ear cant hear so if you cant hear them wtf does it matter? i guess my real question is is it going to hurt anything not to have one?
got me... im not even sure of what, what i said means...
from what i can figure though the SSF should be
set lower than the port tuning so you may be
able to get away with not having it... but i am
in no position to advise you more than that...
im sure there are external filters that can keep
you safe though... wouldnt a high pass filter
set to ~35hz do about the same as a SSF???
you should set an SSF to 3/4 of an octave below tuning frequency so on octave below 35 is 17.5 so you should set it to about 30-31 Hz
this means if none of your songs go below 31 Hz, you'll be fine
and yes, you can buy an external SSF
The subsonic frequency should be tuned to 1/2 octave below tuning.
What is an octave you say?
An octave does not have a predetermined value. A change in frequency of a multiple of 2, means a change of one octave. An octave has to have a starting point. If the starting point is 1000hz, one octave up is 2000hz. One octave down from 1000hz is 500hz. Equalizers commonly have one octave spacing between their slider controls.
So in your case, set the SSF to 35-[(1/4)35] = 26.25Hz
without a SSF if you play a frequency below the port tuning your sub will act like it has no box. it will be free air. this can damage the sub and burn the coils. so ssf yes although most song dont have 20-30 Hz frequency its just to be safe.
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
RandyJ
