Do I need a second batt
You don't have to add a second battery if its not needed. But chances are if you are needing to add a HO alternator than you probably need an extra battery. The alternator wont damage anything without adding additional batteries. Alternators regulate there amperage output. It will only put out high amperage if needed
Naw I have a red top under the hood, so I should ok, right? I do have a small xs agm I got from mylows just in case. Again, thanx guys, enjoy your judgeship this wkend jim. If we need your help, I will a reachout. Y'all have fun, ya hear!!
My usual order of electrical upgrades is:
-Big3
-Make sure you have sufficient size wire and solid ground to amp
-Deep cycle battery to replace stock battery
-Add 2nd same type deep cycle battery in rear
macsdad
boom-boom
macsdad
Birmingham, Al
ngsm13
