do i need a Ho alt
chalino22
I am currently runnig a alpine v12 1000w amp and i wanted to upgrade
to a 2000w kicker or mmats amp.
my current alternator is 90 amps . to run 2000 watts would i need a ho alt and if so what amperage, and what else might i need .
(currently with the 1000 w alpine amp when i crank it up the system shuts down because my voltage drops) what can i do to fix that until i get a ho alt.
and what battery would be good? yellow top?
so i would be ok to run 2000 watts on a 90 amp alt for about a month or 2 with some battery s until i get some cash for a ho alt.?
any suggestion for a ho alt>?
lol, your amp shuts down with 1000 watts but you want to know if its alright to run twice that power. use your brain //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
wow thanks for helping me:).
that was not the only questioned i had
An isolator and a couple of batteries near the amp(s) should help you out until you can afford a HO alternator. Of course, when you price the isolator for a HO alternator and a couple of batteries, it may make the HO alternator look more affordable!
ETA: As for the size alternator you need.... I say the biggest you can afford and at a minimum, at least DOUBLE what you are running now: 180 amps!
thanks
chalino22
chalino22
Chicago
chalino22
