As have I, for nearly 5 years... Including mixed batteries at various times (red/yellow tops, optima/kinetik, and now all optima).I've had dual batteries for years, and have never had this problem. Sucks to be you.
I hardly ever listen to music with my truck off.A few things come to mind;
Do you "bump" much with the engine off?
Do you normally only drive short trips, with no extended periods with the engine on?
How big is your alternator?
It's possible that your draining your batteries and then not giving them a chance to recharge properly.
Also are you sure your amp is turning off when the HU is off? If you hear a "thump" when you turn your stereo on then your amp may not be powering off, which would drain your batteries.
It sounds like what someone else said, one of the batteries is bad and is draining the other battery.
Have the batteries load tested individually at an auto store.
nG
130 amp should be plenty for your rig. I don't know. It seems you have a problem with your electrical system, not the amp.I hardly ever listen to music with my truck off. I usually drive short trips just from home to work and work back
I have a 130amp alternator. About 4 months old.
I believe my amp is turning off when i turn the car off.
Ill double check everything as soon as it stops raining here //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The battery came in the truck. So I dont think they can warrenty it. The battery sticker says it was made ( 11/05)If the optima is under warranty, see if you can trade up to a yellow top //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
nG
Now that i checked i acidently left the light on that lights up my bed //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I think that is what may have killed my battery upfront. And now that i looked more i noticed that my fuse to the 2nd battery snapped so i need a new fuse. So my subs cut out at high volumes is because it was only running off of my kinetik. So now i need to wait til tomorrow to buy a new fuse.It won't recharge? I would still be looking for what killed your batteries. I think something else is going on.
