Do I need a 2nd battery isolator? Or whats wrong?
porksoda
Ok well this is whats going on. I recently installed a HC600 to my set-up *specs in sig* then it worked great for like a week. But sense last night everytime i turned it up just a little bit my amp will cut out and turn off but when i would lower it, it would turn back on. Is that caused by my battery or not? Also this morning when i went to turn my truck on it was dead. Like really bad. My interior lights wont even turn on. I have a friend that told me i need a Isolator to fix it. But I havent heard much of them before.
Also the battery upfront is a RedTop.
Thanks alot!
Check your ground and rca's, and what kind of power wire is going to that amp? You should at least have 4 gauge..
Yeah i am running 4 gauge stinger wire. It just started all of a sudden tho kinda wierd
Alright ill double check again.
MY buddy said a battery isolater will keep my front battery from getting drained or something like that. Is that true?
take the isolator out before you do anything else and see if the problem goes away............you really dont need an isolator.........
Well i dont even have an isolator at all i just have a fuse between the batterys
then check all your connections, remote power and ground........then id tap on the amp when its powered on to see if it shuts down when it vibrates......and then check your voltage and see what its doing when to turn the volume up
porksoda
porksoda
USA
DidUHearThat?
