Do Capacitors work? CAST YOUR VOTE!
Do capacitor work?
  • yes
    Votes: 31 44.3%
  • no
    Votes: 39 55.7%
  • Total voters
    70
If your lights stop dimming after you put the cap, then basicaly you still have the same electrical problem but you can't see it anymore.
PRECISELY and its only a matter of time before the dimming comes back, you eventually kill your batt and then alt, and look at all the money you 'saved' by buying a cap, then later a new alt and battery instead of doing things CORRECTLY and buying a high output alternator!!
Do caps help dimming issues and/or prolong alternator life?
NO and NO
And anyone saying otherwise needs to either work on their reading comprehension or needs to learn basic physics...
of course they can help dimming - they don't help in every situation, and helping dimming isn't helping your alt/batt, but yes - they CAN improve dimming.
They reduce the distance between voltage peaks and valleys in the charging system. If your amps are just barely maxing out the alt dropping you from ~14 to 12.5v and the cap can store enough charge to cover, or close that gap then yes, obviously you'll see it in the lights.
If you've got a giant system and your alt doesn't have a chance and your voltage isn't ever much over 12, then no - the cap V will always be = or close to = the batt V which will have no effect on lights.
Horribly worded poll.
Yes, they work. To say otherwise would be silly. Ever look inside of basically anything electronic lately? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I voted Yes because it's the truth...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if the amps are "just barely maxing out the alt" your voltage will not drop to 12.5. Nearly EVERY battery on the market floats at 12.9 to 13.2. Remeber that your galvanic cells rest around 2.2v each. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If the amp was "barely maxing out the alt" as you say the voltage would not drop much below 13. Secondarily do you have any idea the kind of power a battery puts out before it drops to say 12.5? A hell of a lot more than ANY conventional cap can ever have a snowballs chance in hell of storing. If you do the math it takes thousands of farads to equal one battery's storage capacity. This is why manufacturer's use batteries to start vehicles, not caps. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Lemme just say in a friendly manner, wrong again. The cap, once discharged is an additional load on the overstrained alternator, leading to even faster alternator death. (remember you alt is NOT designed to recharge a battery that has been deep cycled - it is designed to power your cars accessories and maintain the battery's charge. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )Secondarily unless you have grounding issues, the cap, the battery, and the alternators output are all going to be the same...
Again putting in a cap to remedy light dimming is analogous to throwing a roll of toilet paper in the ocean in hopes of lowering the oceans level...aint gonna happen
Well duh! lol
But did you read the context of his question?
If you did you'd have said NO. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Why did you edit your post starting with wrong again? Eh yota...
to add tact (i dont want to offend anyone...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif) and to make it easier to read and debate
imaspaceguy90
LOUDS10BLAZER=SCAMMER
imaspaceguy90
Melbourne,FL
1loudsuv
