diy big install
  • 1
chevygang
I have pictures of the specs of what I will be using. I am trying to figure out the amount of amps I will need for the amount of speakers I will be installing. I have 20 powerbass mids I plan to install and so far I have 2 4000 watt lanzar amps. If you can give me any info or suggestions on the amount of speakers per amp I should use or setting them up in series or parallel. Thanks check attached pics for specs
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
chevygang
chevygang
ocala, fl
chevygang
audiobaun
    May 19, 2024
    May 19, 2024
