dissapointed with this setup!! very angry..
Ali1
e6300 FTW
3,643
U.S.
Okay, as you guys may know about my previous setup, it was far more louder than this new setup I have. my previous setup was a pair of 15" L7s (2ohm) on a zx2500 @ 2ohms. Electrical system consisted of two optimas in the back with a redtop upfront, stock alt, and 1/0 throughout vehicle. Gain was set a LITTLE UNDER A FOURTH. I had no need to turn the gain any higher as it was plenty loud. I had no intention on touching the bass boost or even raising the bass level from the headunit. To make a long story short, I swapped my zx2500 with a xxv colossus, swapped subs to 08 models (2ohm) so I can acheive a 1 ohm load on each channel, swapped both optimas for a single powermaster d3100 (largest battery powermaster makes), swapped jvc avx33 with alpine x100, and I noticed a huge decrease in output. I had to turn the gain all the way up to 95% in order to hear half of the output I got with my previous setup. At this point, I am very dissapointed with the overall setup. All connections are tight and secure. The battery swapping would make minimal difference in the output as described above, so I don't think the battery made the difference in output. As for the amp, its wired to 1ohm on each channel, essentially giving each sub 1600(not factoring in many variables such as impedence rise, voltage drops, resistance, etc.). My only other option is the head unit. I know these alpines are terrible in terms of voltage preout, but I've used other alpines ( 9856,9885,9855) which all have 2v preout and I've never had to turn a gain that high to hear audible output. any advice is appreciated. If I have to, I may ditch the HU and look into the pioneer 9800. Help me out fellas
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
first off y would you swap out the zx2500
Because I got a pair of BNIB 2008 15" L7s for $100, essentially $50 a piece. Zx2500 isn't stable to 1ohm, so I sold it. I also got another deal on a BNIB XXV colossus for $450 . Couldn't pass up these types of offers, so I jumped on them and then swapped those L7s for dual 2ohm.
I've had the same problem with a 2v Pio HU. Had to use LOUDNESS on the HU to get decent output from sub/comps, even with gains nearly maxed out. Swapped in a Kenwood 4.5v and turned the gains way down, but it was MUCH louder, cleaner, and fuller sounding. Even though it's not supposed to make a diff it did in this set up, so no more 2v HU's for me...
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
776
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
Ali1
e6300 FTW
Ali1
U.S.
audioholic
