Dimming lights
groove269
guys....my lights dim to the point where i just turn them off sometimes because it gets annoying. Ive had a cap sitting in my garage for the past 6 yrs (never been used) should i install that baby? i was also thinking of yellow top battery. What do you guys think?
Adding the 2nd battery will help,what size wire are you running?Oh yeah you can leave the cap where it's at.
i have a dodge charger so my battery is in the back, not sure if theres room for a 2nd battery. Im running 0/1 gauge on sub amp and 4 gauge on HP amp.
Try the Big 3, it wouldn't hurt at all. Usually solves a lot of peoples problem with dimming. But if it's still dimming, go with a second battery.
Lol. Your amp is probably suffering bad from low voltage if the lights are dimming that bad. Def do the big 3. I wasnt aware chargers had their batts in the trunk though?
yup...huge engine so they placed the battery in the back. Its a pretty small one too (the battery that is). Would the big 3 eliminate the dimming?
it'll drastically make a good difference. That's your first step. if that doesn't do it, "try" the cap, after all....its free, see if it helps if not, take it back out and save for another battery:)
There's a very good chance that doing the big 3 will take came of the dimming.
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
659
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
groove269
groove269
VENICE, CA
DidUHearThat?
    Jun 1, 2024
    May 31, 2024
