Thanks. WTF am I doing wrong now, I get crazy readings when testing the rear channels (bridged). I am using a -3dB 45Hz tone because it's for my small sub. I turn the gain ALL the way down and I'm getting around 28V. Any ideas?the gain control does not work like that.
The reason why I think it's unreasonable is that the gain is ALL the way down and it's reading 28v. This is out of an amp that does 200x2. I think something is wrong there.28^2/4 = 200w
So it's not all that unreasonable. Does something not sound right with the sub connected ? Or are you just freaking out about the voltage reading ? Do you have bass boost or anything turn on ? Equalizer settings on the headunit ? Where is the lowpass crossover set ?
Keep in mind that the gain isn't a "wattage controller".....it is possible to obtain full power from an amplifier with the gain set to minimum....in fact the amplifier was intentionally designed to do such.
So it is better to turn off the "Bass EQ" even though it's running a sub?The "Bass EQ" is part of the problem. Like squeak said, amps were intended to be able to reach max power with the gain set to min all depending on the signal voltage. What HU do you have?
The Bass boost double the amount of power the amp is trying to make for every 3dB of boost applied. If the amp has a fixed 12dB boost (sadly not that uncommon) it is trying to make 16x the amount of power that it should for the same gain settings and signal voltage with the boost turned off. The amp simply cannot do this, will clip and many times either go into protection, blow the speakers or blow itself.
The purpose of the gain is to match the input signal voltage from the source to the voltage that the amp needs to make full power. Since every source unit is different (there is no industry standard for pre-out voltage) an amp needs a range of adjustment to be compatible with as many different sources as possible.
