Difference Between Power/Ground Wire
chibahawk
oe squeezer
Okay, I have like 20ft. of 0/1g wire in my car but it's not actually hooked up to anything right now.. thing is, my wire has silver strands in it, so I'm guessing it's not copper.. now I just ordered 0/1g wire from Knukon and it's got copper strands..
if the original wiring I've got is any different from what I've got now will yall let me know? I see some people label 0/1 GROUND wire and 0/1 POWER wire but is there really a difference?
Kolossus Kable 1/0 Black/Silver Power Wire
vs.
eKo Kable 1/0 Silver Pearl Power/Ground Cable
if anything i would have to disagree because the higher strand count makes its more of a ***** to get into tight spots etc.
As stated - power/ground wire are the same. You should use two different colors in your install though so you can tell which is + and - just by looking.
Kolossus Kable is just that - Oversized with a higher strand count. It uses tinned oxygen free copper. It competes directly with Stinger and PG
eKo Kable is more like the industry standard for wire gauge - it uses Oxygen Free Copper. The eKo line was introduced to compete with the lower priced knock offs that sell you 2 gauge wire in 1/0 jacket. This cable is aimed at AudioPipe and Streetwires and the generics found on ebay. We however give you full specs of our product, the same can not be said about the others.
i hate that crap. way to go knu.
chibahawk
oe squeezer
chibahawk
NYC
baseballer1100
