SuperSaeYoung
Banned
99% of the people see it's been used on the speaker boxes, website, manual, speaker itself, and people on forums.RMS means "root mean squared" it's a handy way to find an average variance from 0 from a group of numbers (positive and negative mixed or the mean can be derived without the square and root). RMS does NOT mean power.
POWER = square root of (current * impedance), or current * voltage, or whatever other variation of the equation
IMO unless you're playing one specific tone at a specific record level any form of "precision" gain setting is pointless. To match all potential unknown program material at unknown record levels cannot be done.
My method is head unit volume around 2/3 to 3/4 depending on the head unit, gain it up til it doesn't get any louder when you turn it up more, then turn it back a little bit. Except in cases of grossly over-powering speakers I've never blown stuff up with this method. The point is to have your max undistorted output somewhere before the top of the dial on your head unit so that you're not pushing that into a clipped signal when you need a little more gain to overcome low record levels. Anything you throw in for source material beyond your test track will require a little discretion and knowing when to back off.
And I still have yet to fathom why everyone feels the need to use the term RMS in regards to an AC signal, considering 99% don't understand what it means, where it comes from and why it's not relevant.
I thought power was
Code:
P=I^2*Z not P=SQRT(I*Z)
