Did i blow my sub?
DylanBeatz
Ive had this sub for probably 8 years, its a 12" Kicker CVR and its always been fine and today when i was bumping it suddenly shut off. I pulled over and opened the trunk and my box slid all the way to the rear of the trunk. The sub was touching the wall of the trunk so the cone had to be hitting the wall of the trunk hard. So did i blow it this way because of the contact? Its not making any noise at all. It's never done this. All the wires are fine. It didn't smell or anything or make any weird noises, just stopped playing.
Any ideas on how to check if its blown? Thanks
If the woofer couldn't move while it was trying to play then yes you burned up the coil. The woofer needs to move to cool itself, it if couldn't move it was just building up heat and fired the coil. Get out your dmm and see what the coil reads
thanks man, exactly what do i do with the dmm? Never tested a sub like that before? Put the positive in the positive and the neg in the neg and test for what?
okay so im pretty sure my sub is fine, it read 2.2 ohms consistently. So then i connected my dmm to my amp and played a test tone as if i was setting the gain and there's no output voltage at all. Its lighting up though. So im very confused. Does this mean my amp is blown? How do i check the fuses on it?
I'm really appreciating the feedback guys
Well i realized the protection light was on the amp and i took it to a local car audio shop and they tested it for me in their shop and the guy came back saying that it wont get out of protection mode. He said its destroyed. We also both noticed that when you pick it up and carry it that theres something inside that sounds loose.
It was a jbl p180.2. That thing was a great amp, held up for so many years and put out more power than it was rated for. I wonder what killed it, do you guys think it was because when i put this system back in my car 2 days ago that i never mounted anything in the trunk? Everything was just sliding around, i never had it like that before but i was just lazy two days ago, was meaning to get some velcro to secure everything.
alright thanks a lot man, hopefully it just died from old age and not from sliding around cuz then i feel dumb but i will definitely never let another amp and box slide around ever again
Thanks for the help everybody, you guys were great, very helpful
DylanBeatz
DylanBeatz
Wisconsin
DylanBeatz
