Diamond D5 1200.1
sotelomichael
Pharr, Tx.
Diamond D5 1200.1
Used, scratches on heat sink. Works great, guts look brand spanking new.
Monoblock Car Amplifier
1200 Watts RMS x 1 Channel @ 1 Ohm
Power / Protect LEDs
Adjustable Low Pass Filter
Adjustable Subsonic Filter
0° / 180° Phase Switch
Adjustable Input Sensitivity (Up to 5V RMS)
Strappable
Optional Wired Remote Gain Control (Not Included)
Massive Proprietary Heatsink
Nickel Plated Solid Brass Circuit Board Mounted Power / Speaker Connectors
Fly Cut Billet Aluminum End Plates
Fully Adjustable Mounting Feet
Fully Regulated Power Supply
2 oz. Copper Circuit Board
Dimensions: 11-1/2" L x 11-13/16" W x 3-13/16" H
175 shipped
Ups ground insured and well packaged
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
It should be fine as long as you're not looking to upgrade in the future.
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
sotelomichael
sotelomichael
Pharr, Tx.
aztec
    May 24, 2024
