Design Questions for : 2 15", ct sounds stratos, 32hz slot port, trunk wall?
  • 4
kicker
GIT-R-DONE
305
auburn ne
Vehicle : 06 impala
Location in the vehicle: trunk
Space available (L:36"x W:36-38"?x H 17-18"):
Subwoofer*make and model: ct sounds strato d1
Subwoofer*Size: 15
Number of*Subwoofers: 2
Type of*Port* center slot /offset If it fits better.
What type of music do you like?: decaf, rap, country, rock
Is your goal SPL or Everyday Music?: everyday music
Tuning Freq (Hz): 31-35?
Volume : not sure
Questions: anyone willing to help with a design and cut sheet for this? Will be ran off of a hifonics brz1700.1 for now may go with more power down the road. I like songs in the 28-40hz range the most.
Subwoofer*size: 15"Subwoofer*type/ impedance:*Dual 1 ohmVoice coil (diameter): 3" (76.2mm)
FS: 31.40Hz
QTS: 0.606
QES: 0.679
QMS: 5.593
VAS: 74.74 liters
SPL: 87.2 dB (@ 1w/1m)
Xmax: 13mm
Displacement: 0.265 ft3
Magnet weight:195 Oz
Speaker connector: 12 Gauge
Resonant frequency: 30.5Hz
Coil inductance:*2.10m
HSd:*844.963*cm2
BOX SPECIFICATIONS:Sealed: 2.50 ft3Ported: 3.20*ft3*(Port Freq- 31.69Hz; Port Diameter- 4.1"; Port length- 7.9"
Doing a box 36L x 38W x 18H, 1.5" thick all sides, is 10 cubes before displacements, .53cuft for subs leaves 9.47 before port, I'm just not sure how big to make the port I think max width would be 5" internal, and 15" high not sure on length. It will have to be built in the trunk.
Just because you have x amount of space to work with doesn't mean you should be using all of it. You need space around the box so the air pressure can get into the cabin. If you don't have enough room around the box, you will loose output because the air is restricted from entering the cabin. Are you planning on walling off the trunk with the subs facing forward? Does the rear seat fold down?
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
Not sure if this is reliable but trying to figure it all out on my own at this point. Does this look good?
747
280
625
kicker
GIT-R-DONE
kicker
auburn ne
kicker
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
