Design Questions: Downfiring 2 SA-12 in 3.59 cu. ft. at 35hz aero ported
Hemanshs85
Vehicle : 2010 GMC Sierra Crew Cab
Location in the vehicle: Under rear seat which will be lifted 3"
Space available (Length x Width x Height): 14"x63"x(10" front, 7" back")
Subwoofer make and model: Sundown SA-12
Subwoofer Size: 12"
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): Aero
What type of music do you like?: Rap, Pop, and Rock
Is your goal SPL or Everyday Music?: Everyday
Tuning Freq (Hz): 35 (as recommended by Sundown site, but open to other frequencies)
Volume : 3.59 after all displacement except port
This will be the first enclosure I've ever made, and the first subs I've ever had. I'm going to lift the rear seats 3" and then install this box underneath them with about 1" of clearance to downfire with the ports facing forward. Will this be enough space for them? How much port do I need?
I liked the idea of the aero port because it seemed more space efficient and much simpler for a first box that isn't a cube.
View attachment 26537720View attachment 26537719View attachment 26537718
I made a tentative design using SketchUp. The ports in it are 6" diameter and 8" long, I have no idea if these are accurate, mainly put them in to have a better idea of how the box should look.
Do you guys think this enclosure will sound good? If not, what changes would you suggest I make?
Any help is greatly appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also planning on filling it with that poly-stuff. Do you guys think I need any braces? I'd really appreciate at least confirmation that I can realistically fit these subs cause I would like to order them while the sales are still good.
2 6" aeros in that air space would need to be over 30"long each to get it tuned to 35. Youd need 2 4" aeros at about 16' each. Its gonna be rough to squeeze those in there, and youre going to need to re configure your sub and port locations.
If I were you I would go with a couple SA-8V2 instead justto cut down on the headache
My opinion is to go with the tens, thanks for using the format for this thread! Good to see someone did their homework before posting!
Thanks! What modifications should I make to my design to accommodate 10s? I haven't bought the subs yet, all I've ordered is an AQ2200 after a long discussion on another thread. I ended up deciding to get the Alpine SWR 12 in exchange for a higher quality amp than I originally planned to purchase. If I bought the SWR 10s would I still be gettin all the value out of my amp?
Hemanshs85
Hemanshs85
Oklahoma
Hemanshs85
