Port help
What are the final goals? ie: Net volume and tuning?
Tuned to 32 hz:
as you can see the aeroport diameter is 6", but i couldn't find PVC in that size so i bought two 3" PVC pipes... how do i have to cut these to keep my 32hz tuning?
Looks like its a 6in port but pipe thickness is 1/4in 6 1/2 outer diameter you can use a thinner wall pipe if you can find one
i bought two 3" PVC pipes... with the 6" port it had to be 13" in depth to reach 32hz... do i have to cut both 3" PVC's to 13" to reach this same tuning? or should they be longer/shorter?
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
THATpurpleKUSH
