So id like to go with one 18 in Fi BL, definately a ported box...
Its going in a 1994 grand prix.
Id like it tuned to 34hz...(is this a good hz?)
I have lots of room when i take the backseat out.
Heres the specs on the sub
Fs: 33.1 Hz | 32.5 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 6.43 | 6.54
Qes: .53 | .49
Qts: .49 | .46
Mms: 280g | 290g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 169.7 l | 169.7 l
Spl: 92.5dB 1W/1m | 92.6dB 1W/1m
Bl: 12.8 N/A | 19.0 N/A
Xmax: 21mm
Rms: 1000W *
Sealed box: N/A cuft
Ported box: 5-10 cuft @ 30-37Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.750”
Displacement: 0.23cuft
THANKS, any more ?'s ask me.
PS:this will be on or around 1500-1800 watts.
Qms: 6.43 | 6.54
Qes: .53 | .49
Qts: .49 | .46
Mms: 280g | 290g
Xmax: 21mm
Rms: 1000W *
Sub OD: 18.500”
Cut ID: 16.750”
