Design me a box anyone?
Whats up guys i was wondering if anyone cam design me a box just blue prints no actuall manual work. Its a wedge box max dimensions are 55W•16.5H•9.5D1•4D2. Id like it ported at 32hz. Its for a Fi Q 12
Build a enclosure almost like a sealed box except you're going to stick an aero port in it. Using same dimensions as you provided 55w 16.5h 9.5d1 4d2, add a 4" diameter aeroport 12" long, which will be tuned to 32.17hz and final net volume will be 2.191 cuft. Or you can do a 3" diameter aeroport 6" long, which will be tuned to 32.17 and final net volume of 2.245 cuft. I already did displacement for sub and port. Everything is .75 thickness. The Fi Q 12 is 7" mounting depth so double check everything before doing it. You can check out precision port at partsexpress.com. They make 3" and 4" version kits. If you want more net volume, I would suggest not doing a wedge box.
C1500martin
C1500martin
Cali
blazian87
