Deciding between these 6x8s
If you aren't going to amp the speakers or add a subwoofer, it makes little difference. In fact, you'd probably be better off with your stock speakers....unless they're blown.
Come on....cut the guy some slack. Maybe he's using stock speakers or he doesn't want or can't afford an amp.
We gave the guy an honest answer. If you aren't going to amp your speakers, there's no point in purcashing them in the first place. His factory cd player's internal amp might be 5 - 10 watt rms. With such a small amount of power, what's the point in "upgrading" your speakers?
He says in the first post he has a jvc headunit.
This is true. It can end up sounding worse than your stock speakers in some cases. Especially laking mid bass. Just trying to help, I've seen it before several times.
My mistake. I haven't revisited the opening post since I first read it...
EDIT: Even if it is an aftermarket cd player, the internal amplifier is likely 10 - 15 watts per channel (if that). My point is still pretty valid...
If I get the alpine iDA-X305 which puts out 18 W x 4 RMS, will it blow my stock speakers in my car? I have a 2002 Ford Taurus SES Deluxe. Also, would it be wise for me to upgrade to these: Pioneer TS-D6802R (tsd6802r) 6" x 8" Speakers Car Speakers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix
I know they have high RMS, but wouldn't it still be louder and better than my stock speakers, since they need to be able to keep up a little with my 15" SDC2.5 that I'm putting in.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
AVI is still making car audio? I have some really nice 5.25 components I bought back in 04, I think. I run cdt 6.5 pros now, but in my memory...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
430
819
alleneagles
alleneagles
Dallas, TX
misfit138
    Jun 15, 2024
    Jun 15, 2024
