Dead Battery or dead something else?
JunkTitleGolf
Ok so I have a 1995 VW Golf with a stock alt. and I have the big 3 done in 4 gauge. I also did an extra ground while doing the big 3. Anyways to the question. I used to use my Power Acoustik TS1920 amp only using one channel and my Orion 4002 using only one channel again. Well, I removed the Power Acoustik amp and have only been using the Orion and it's now bridged and doing I think 400 wrms. The question is sometimes I have a hard time starting and sometimes it won't start. Everything turns on it just won't even turn over. The battery is an el-cheapo from Walmart still under warranty. So does it sound like bad battery or something else?
battery is usually the first offender and/or the starter could be going.
test with a friends battery first to see if you don't have much in the way of amps in your battery, wet-cells once drained can suxor.
A good dry-cell would be a good long-term decision.
if the alt isnt charging the battery or hasnt in a long time the battery could just be dead from that. best thing to do is get it tested. at most places anymore (autozone and the like) its free
JunkTitleGolf
JunkTitleGolf
Corydon, IN
audiolife
