DDbump Wall Build
mlstrass
Shaggy DOA
Well thanks to my camera fuxoring on me I only have about 1/2 the pics.
Car is a '98 Grand Am I believe
Equipment:
2 15" MT's
DDZ1A at .5ohms //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
2 Stinger batts
HO alt
Diamond Hex comps
comp amp - don't remember
Box - 9cubes @ 37hz with double baffle and plenty of bracing.
Did 2 runs of 1/0 to the rear. Unfortunately one of the subs is F'd and didn't ohm right, but he threw it in anyway. Makes a horrible slapping sound when you turn it up, but he has a recone and should be doing that tonight.
Dance floor was welded to the body with 1/8" steel brackets that I bent up. Shit is solid as a rock and won't be going anywhere. Box was built outside the car and took 3 of us to wedge it into place.
Here's all the pics I had:
Equipment:
2 15" MT's
2 Stinger batts
HO alt
Diamond Hex comps
Mike you and your walls i guess. JOB well Done probably would be better if you had white man skills
flat white port is MUCH easier to paint and has some contrast then. Not a pretty wall, but functional for sure and should beat his car to death once the both subs are 100% and he turns the gain up.
mlstrass
Shaggy DOA
mlstrass
Illinois
DDbump
