Dc level 3 18?
  • 5
Spldecendant
Ny
I have my daily driver that I did a previous build in the idea was light weight but somewhat loud. I did 4 15inch kicker comps in a 10 cubic sealed enclosure (birch). im looking to lighten it up even more I see that the level 3 18's weight 29lbs a piece. I am considering putting 2 of them in 8 cubic ft sealed enclosure my question is there any lighter 18's neo? Or something along those lines or motors I can build better and lighter woofers than the level 3's?
what amp u have? couldn't u do like 1 FU 1250 18 ported with like 2k rms, I know u losing cone area but they are comps, I would think 2 fu 15 (or sa) be louder ported with good power
The amp is an audiopipe 3000d good electrical comps where actally decent 44-45 on burp I don't play music full volume though they would break. My other truck has a ported enclosure this build in here I like the sealed box for the slight sq advantage
maybe 2 sundown 15 E'S sealed be good (22 pounds each or so) seen reviews sealed sounds good they say., they can take 800-1k with gain down..
go 9 cubes aero ported bud. Your 4 15s will be a good bit louder than them if you keep sealed.
Factory. 2021 Chevy Silverado custom trailboss
583
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
669
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
585
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
Spldecendant
Spldecendant
Ny
Papermaker85
    May 18, 2024
    May 16, 2024
