DB Drag street stock set up
cf2004
Lima, OH
I am thinking of building a Street Stock A or B setup
Anyone got any suggestions on what would be good.
TOTAL RMS power rating is A-1000watts, and B-2000.
No woofer limit.
I was maybe thinking 1-15" DC level 2 on a Audiopipe 1000d for street stock a. That could do well.
ideas?
No woofer limit.
ideas?
has to be a main stream amp like alpine,kicker,fosgate,and so on .woofer has to be steel stamped basket and 2.5 inch voice coil only.oh and no crx
k
what do you think would be good
I was looking at the rule book and see that is said the stuff had to be able to be bought from everyday auto retailers ( i read that as i could use AP b/c the local shop is autorized retail dealer for them) and non competetion level stuff, but could seem to find anything more specific. i.e 2.5" VC only..ect. do you happen to have that info?
kicker L5 from 2005 or even the newer L5 12 (08 model).2 of them on an amp that does power at 1 ohm
only if steel stamped baskets,i was told you can use the dd 1500 series subs,and also try an alpine 2000 watt amp.i was gonna build a street stock b set up last year for my son ,so i've done alot of research on what amps and subs that could be used
low end woofers ,with decent amps .i would try the dd 1512 woofers and a good amp .the rules are always changing every year so you may want to check with your local db drag judge to see what they've done this year.we were going with the dd 1512s woofers and a autotek ss 1900 amp,termpro did have a list of things you could use
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
512
744
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
484
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
618
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
cf2004
cf2004
Lima, OH
mylows10
    May 24, 2024
