cutting circles
I use nails and a really big hammer.
I just give the piece a mean look and it cuts a hole in itself in fear. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
That or i call up Chuck Norris and he'll give it a hefty roundhouse kick if the box is a little too stubborn.
I thought this was the preferred method //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif lol
I use a Rotozip and a wooden yard stick and I take all 3/4 in one pass. Starting from two inches on the yard stick where I have a hole that I use as a center; I just drill a small hole the length of the radius I need to cut. Then i stick a pen in the hole and rotate it around to make a perfect circle.
I'm pretty dam good with the Rotozip. I touch the line (but not take it) all the way around and only vary about 1mm. The bits eventually break but Lowes has a warranty on them so when they do I just take them back and get new ones.
I usually just use an upcut spiral bit and just do 1 pass... it has worked well so far and nothing has been broken, still sharp too.. i might just try doing a few passes next time but my question is...
if you do 2 or 3 passes doesnt it makes the tip of the bit really dull as that is the only part touching the wood as apposed to the whole bit doing work?
If you have problems with the center piece moving you could just save the last inch for a jig saw. But a steady hand and patients towards the end should could work too.
bigmandengo
bigmandengo
wisconsin
BloWNMind
michigan born
    May 14, 2026
michigan born
    May 14, 2026
