B bigmandengo 10+ year member Member 100 0 wisconsin Feb 3, 2008 #1 is it ok to make a full cut right through the mdf right away with a router or make small cuts at a time? Click to read more...
revrider1 5,000+ posts Hmmm... 30,475 5 Down South~3rd Coast~TX Feb 3, 2008 #2 i use a jigsaw, just steady. I do make more than one cut though
OP B bigmandengo 10+ year member Member 100 0 wisconsin Feb 3, 2008 Thread Starter #3 i mean go all the way around but do you want to take out like 1/4" at a time or is it alright to do the full 3/4" right away
JimJ 5,000+ posts Tangled Up in Blue 32,922 107 Hillsborough, NC Feb 3, 2008 #4 Do multiple passes. Doing it all at once is a good way to toast bits.
RAM_Designs 5,000+ posts SketchUp Master 21,735 362 Rockwall, TX Feb 3, 2008 #6 I usually do 3/4 MDF in either 2 or 3 passes...normally 3.
B BrianChia 10+ year member CarAudio.com Elite 1,294 0 Knoxville/Nashville TN Feb 4, 2008 #7 I'll say 3 passes for 3/4" MDF. I've snapped bits trying to do it in 2.
M mlstrass 5,000+ posts Shaggy DOA 10,908 12 Illinois Feb 4, 2008 #8 1/4" at a time is how I do it as MDF is pretty hard on bits...
bjfish11 5,000+ posts FisherCustoms.com 5,039 9 Garden Plain, KS Feb 4, 2008 #9 Awww.... the joys of using Trupan. 2 passes works well for me. But, seriously, the more passes the better. Not only is it bad on your bits, but its bad on your router as well.
Pl8er 5,000+ posts Can you solve it? 5,216 3 Ahwatukee, Az Feb 4, 2008 #10 Can you guys explain passes? I have a feeling I've been cutting my holes incorrectly. *shoots himself in the face* Wait, I think there is more than one thing here. If talking about a router, that is what I do too. But if talking about a jigsaw, are there passes?
JimJ 5,000+ posts Tangled Up in Blue 32,922 107 Hillsborough, NC Feb 4, 2008 #11 Using your plunge router, you simply lower it a little more every pass, until you've gone through the material...
bjfish11 5,000+ posts FisherCustoms.com 5,039 9 Garden Plain, KS Feb 4, 2008 #12 Yea, you cant make passes with a jig saw. I think most of the people here were talking about using a router.
OP B bigmandengo 10+ year member Member 100 0 wisconsin Feb 4, 2008 Thread Starter #13 yea i was refferring to a router
Abel 10+ year member CarAudio.com Veteran 2,190 3 Chicago,Il. Feb 4, 2008 #14 Roto Zip with home made circle Jig FTW!
brokeitagain 10+ year member auto body tech:) 334 0 MO Feb 4, 2008 #15 i usually go 4 passes with a 1/4'' spiral bit seems to not make the router scream so much.And im hoping for a little longer life out of the bit
