2 L7's in a regular cab?
Could you possible get some rough measurements? Shouldn't be too hard to squeeze out about 2 ft^3 sealed behind your seat, mounting depth will dictate the most though, and is what will take up the most of your legroom.
I can get some better measurements tommorow but i think i can go about 53 in. long, 8 in. wide at the bottom, im not real sure about the height or width at the top because my middle backrest doesnt fold down into a console and it will get in the way if I go up very high.
Im 6 flat and 220lbs and I fit 3ft^3 NET at 35hz for (2) 10's in my reg. cab S-10, and I'm satisfied with my leg room.
Snug top is hopefully coming though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
EDIT: Ill sell you the box if interested?? PM me
with those dimensions and assuming a 4" top depth and 16" height you can get 1.91 ft^3 doesn't look like quite enough mounting depth though for 12's but probably 10's would work. Or if you could increase the height a bit would help, or the top depth would be the most beneficial.
tigermax14
tigermax14
Auburn, Alabama
jdc753
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
