Cutout too big? Fix?
Thanks a lot fellas!
I'm going to try and use some thick foam weather stripping and tapping it on with some Gorilla tape. I know the baffles would indeed be best, but I want to try to keep the "stock" asethics of the box before I really go to work on it if I have to.
The total difference in circumference of each cutout is no more than 1/4." Not too bad...
Depending on the box design, you could "double layer" the front board with the driver mounted in it. Cut the hole to the correct size, and then glue/screw the new board over the original. You will have a proper fit and seal, plus add a great deal of strength to the box.
^Only way to go. I would not use duct tape.
I got it fixed!
All I did was get some foam weather stripping from Lowes, cut it to 3/4", and layed it around the inside edge of the cutout. Then I used some Gorilla tape to hold it down. Put the subs back in, and then cut the remaining tape away so you can't even see it.
I have to say it worked great! The subs fit extremely tight now, and no leakage at all.
^^^ don't listen to this fool, duct tape adds mad deebeez...no matter how/where it's used
What about Gorilla tape? Gorilla in my trunk? Yeah!!! I'm not ****'n though...I think I did add dbs from killing the air leakage.
It Puts The Duct Tape On Its Skin
//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
Unless its specific subwoofer duct tape, then yes.
Gorilla tape...King Kong in da trunk!
start over, ive never let a box escape my possession with out the sub fitting right
I don't want to. Or rather I don't want my buddy to have to build this again:
I would figure it out like it were a 9" round subwoofer. They would have about the same cone area.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
528hz
Everything'sMiscellaneous
528hz
In the Space between Space in NM
johnmasters
SPLBassJunkie
    May 21, 2024
    May 20, 2024
