Cutout size for CAB Ultra 12???
slm9s
WA state
I was going to do the cut for the CAB ultra 12 that just showed up on my doorstep. I assumed there would be info in the box on the exact cutout, but no such luck. I know I can call them on monday, but I was wanting to do it this weekend. And I can't find it on the website.
I see the SA 12 cutout is 11 and 1/8th, is it the same?
With the huuuge magnet, I can't figure out an accurate way to measure down to the 1/8th of an inch I want. I'll be cutting it out with a scroll saw.
Thanks.
Thanks.
yeah probably just barely over 11" u could do 11" and then use router or just sand it just enough to fit.. what size box are u doin?
That's about 5.54"...and according to my Jasper jig, 5 9/16" is the closest match. You'll have a little wiggle room for the driver. I'd rather have that than a tight fit, sand a little around, test fit, sand some more, etc.
Or a slightly larger enclosure. Closer to 2.5 is ideal
I'm pretty much at max size taking up my whole trunk.
---------- Post added at 02:44 PM ---------- Previous post was at 02:44 PM ----------
I'm using a compass and then a scroll saw.
I would figure it out like it were a 9" round subwoofer. They would have about the same cone area.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
slm9s
slm9s
WA state
Boomin_tahoe
    May 20, 2024
    May 20, 2024
