Cut out size for ab xfl 10"?
Good luck with that, they don't even include the specs/manuals inside the box either. I guess they want you to call them up ( AB ) to get the specs. If so, that ***** with 99.9% of other speakers/sub companies including these basics specs with thier product.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
236
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
Corybrdmn
Corybrdmn
Dunkirk, Ny
freakin_rican
maylar
    Jun 2, 2024
    Jun 1, 2024
