TheMobius40
I am attempting to install a custom car horn with an Adafruit soundboard. The issue I am having is that the main amp fuse blows whenever the board sends a signal to the amp.
The system is quite simple; power runs to the board and amp, the board is connected to the amp via rca cables, and the amp is connected to a standard PA speaker. The components are powered through the cigarette lighter port (I know this is known as a lazy power solution, I'm trying to make the system somewhat portable).
Here is an image of the setup:
https://imgur.com/XIzkxHZ
The sound board is on the left and power connections at the top.
When the system is plugged in, everything is fine. As soon as the board sends a signal, the fuse in the center pops.
Thank you for any insight.
