Custom Horn w/ Adafruit Soundboard - Amp Fuse Popping
  • 4
TheMobius40
I am attempting to install a custom car horn with an Adafruit soundboard. The issue I am having is that the main amp fuse blows whenever the board sends a signal to the amp.
The system is quite simple; power runs to the board and amp, the board is connected to the amp via rca cables, and the amp is connected to a standard PA speaker. The components are powered through the cigarette lighter port (I know this is known as a lazy power solution, I'm trying to make the system somewhat portable).
Here is an image of the setup:
https://imgur.com/XIzkxHZ
The sound board is on the left and power connections at the top.
When the system is plugged in, everything is fine. As soon as the board sends a signal, the fuse in the center pops.
Thank you for any insight.
Nope, car horn. As far as I know this still falls under car audio.
I am not by any means an expert on electrical systems; hopefully the issue is just a rudimentary oversight on my part.
A: Because you're trying to power an amp with factory 18awg wire.
B: Because your fuse is too small as well. DONT FIX FUSE UNTIL YOU UPGRADE YOUR WIRE.
Test this with a 2ft or so of large AWG wire. 4-8AWG. Place amp close to battery and test it that way. Fuse accordingly.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
TheMobius40
TheMobius40
Vancouver, WA
The Camry
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
